[GRASS-user] compiling 6.3 cvs on ubuntu 64bit
Brad Douglas rez at touchofmadness.com
Wed Jan 24 18:46:48 EST 2007
On Wed, 2007-01-24 at 21:35 +0100, Maciej Sieczka wrote:
> Glynn Clements wrote:
> > Malte Halbey-Martin wrote:
> >> the line was just an example of the error. In fact in every line is a
> >> syntax error before ftnlen  and L_fp...
> > Ah. In that case, my first guess would be that you're trying to use
> > gcc 4.x, whose Fortran support is essentially broken.
> Glynn,
> Does that mean that i.fft and i.fft will not build or work properly
> using gfortran coming with GCC 4.0.3? Is that an issue only with 64 bit
> systems?
It's a GCC issue.  If you want i.fft/i.ifft, you need LAPACK/BLAS
support, which requires gcc3.x + libf2c, etc. at this time.  IMO,
gfortran is broken.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
