[GRASS-user] Can not find v.report
卜坤 bukunu at gmail.com
Fri Jun 8 11:13:36 EDT 2007
I'm new to GRASS.
I use ubuntu, and use the command:
    sudo apt-get install grass
to install GRASS 6.0.2.
However, I feel it is good until I found that I can not run v.report,
and some other modules. I know that these modules are exist in GRASS.
So, should I compile from the source code, or, install some other packages ?
