[GRASS-user] Maximum number of GRASS files within a mapset?
Fri Mar 23 19:38:42 EDT 2007
Paul Kelly wrote:
> > I seem to be running into a GRASS limitation relating to the maximum number
> > of rasters available within a single mapset location, which appears to be
> > exactly 32000.  Attempting to create additional rasters generates the
> > message:
> > ERROR: can't make mapset element cell_misc/test00
Note: cell_misc contains subdirectories, not files ...
> > which seems to be coming from lib/gis/mapset_msc.c:
> >  if (access (path, 0) != 0)
> >  G_fatal_error (_("can't make mapset element %s (%s)"), p_element, path);
> > Is there any way of circumventing this limitation, or is it a hardcoded C
> > limitation?
> I fear it may be a Unix limitation - the maximum number of files in one
> directory.
Or possibly the maximum link count; cell_misc has a subdirectory for
each map, and each subdirectory adds to its parent's link count due to
the ".." entry.
I note that <linux/ext2_fs.h> has this:
	 * Maximal count of links to a file
	#define EXT2_LINK_MAX		32000
So I'm fairly sure that's the culprit.
Changing the directory layout is a proposal for 7.x; until then, the
only thing that I can suggest is to try a different filesystem, e.g.
ReiserFS (ext3 has the same 32000-link limit).
