[GRASS-user] Lambert Conformal Conic location
Miriam España mespana at ugr.es
Wed Mar 28 10:17:16 EDT 2007
Hola Roberto,
> Maybe I'm wrong, since I've never worked before with this kind of
> projections within GRASS, but the bounding box that you have just set
> begins at O°West and ends at 34°East. However, the central meridian for
> your data is 85°West. So I suppose your data is around this meridian,
> not between 0°-30°.
Ok. That point of view is obviously correct  over the data projection.
> Try:
> # g.region rast=your_map -g
> and you will set the region to fix your map and also you will see what's
> really your data's bounding box. After that, you should be able to
> visualize your map:
> # d.mon x0
> # d.rast "your_map"
I cannot do it, because I can import the map without define the location
previously. I detected that the moule r3.in.v5d imports so many rows and
columns as has the region, for what I must calculate it first (I think so).
> The region units can be seen in the "YOUR_LOCATION/PERMANENT/PROJ_UNIT"
> file
> I hope it will help.
> Salu2,
> Roberto.
Ok! Thanks! :).
Saludos!
Miriam.
> Ps: También puedes enviarlo al lista en español, así generamos algo de
> tráfico en la lista ;)
P.D.: Vale :), empiezo a reescribir .
<>   Miriam España Acebal
<>   Ingeniera en Informatica / Computer Science Engineer
<>   Departamento de Fisica Aplicada / Applied Physics Department
<>   G. I. Fisica Atmosferica / Atmospheric Physics Research Group
<>   Universidad de Granada / University of Granada
<>   España / Spain
<>   mespana at ugr.es
View this message in context: http://www.nabble.com/Lambert-Conformal-Conic-location-tf3479692.html#a9714643
Sent from the Grass - Users mailing list archive at Nabble.com.
