[GRASS-user] Error updating GRASS
António G Rodrigues
agrodrigues at ipt.pt
Thu Mar 29 12:16:39 EDT 2007
Just an update about the problem I'm having in running GRASS6.2 in Ubuntu...
The problem occurs (see text below) when I enter GRASS from the GUI
window after choosing or creating an existing (or new) mapset in the
current (or new) location. I tried every possible option, even created
a new GRASS mapset in QGIS, but nothing works. It simply returns to the
comand line (when trying to restart x-windows with gis.m the same happens).
I des-installed GRASS, TK8.4 and TCL8.4, installed everything again, but
doesn't work.
I would really appreciate some help on this, otherwise I'll probably
have to intall an older version of GRASS.
Thanks in advance,
António
Jachym Cepicky wrote:
> Hi,
> the file seems to be ok.
> I greped around
> cd $GISBASE/etc/gui/
> grep upvar gm/*
> and did not found anything useful. Unfortunately, I do not have my
> laptop here, so I can not check the sources now to see, if everything
> is all right.
> Could anybody from the Tcl-masters have a look at the problem?
> Thanks a lot
> Jachym
> 2007/3/29, Jachym Cepicky <jachym.cepicky at gmail.com>:
>> hi, nobody else reported such problem...
>> are u using tcltk 8.4?
>> could you sent me /usr/lib/grass/etc/gm/gm.tcl ?
>> jachym
>> 2007/3/29, António G Rodrigues <agrodrigues at ipt.pt>:
>> > Hi folks,
>> > I apdated to grass6.2 in my ubuntu system using the repositories in...
>> > deb http://les-ejk.cz/ubuntu edgy multiverse
>> > deb-src http://les-ejk.cz/ubuntu edgy multiverse
>> > The problem is that when opening grass it crashes everytime. The
>> error message is:
>> > GRASS 6.2.1 (Europe):~ > Error in startup script: bad variable name
>> "coords(1)": upvar won't create a scalar variable that looks like an
>> array element
>> > while executing
>> > "global coords($mon)"
>> > (procedure "MapCanvas::pointer" line 5)
>> > invoked from within
>> > "MapCanvas::pointer $mon"
>> > (procedure "MapCanvas::create" line 226)
>> > invoked from within
>> > "MapCanvas::create"
>> > (procedure "Gm::startmon" line 11)
>> > invoked from within
>> > "Gm::startmon"
>> > (procedure "Gm::create" line 69)
>> > invoked from within
>> > "Gm::create"
>> > (procedure "main" line 30)
>> > invoked from within
>> > "main $argc $argv"
>> > (file "/usr/lib/grass/etc/gm/gm.tcl" line 521)
>> > Any clues?
>> > Thanks in advance,
>> > António
>> > _______________________________________________
>> > grassuser mailing list
>> > grassuser at grass.itc.it
>> > http://grass.itc.it/mailman/listinfo/grassuser
>> Jachym Cepicky
>> e-mail: jachym.cepicky gmail com
>> URL: http://les-ejk.cz
>> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
