[GRASS-user] File formats in r.in.gdal
Hamish hamish_b at yahoo.com
Tue Apr 22 03:43:38 EDT 2008
Richard Chirgwin wrote:
> In Grass 6.2, Ubuntu build (yes, there's a more recent version but not
> yet for the right build), when importing ECWs in r.in.gdal, I receive
> the "not a supported file format" error. Any ideas?
> The same error occurs with Globe DEM files (although Globe DEM has been
> reorganised and I'm not sure I have found the right header files).
Your copy of GDAL has to be built with support for those formats. Once it
is, r.in.gdal should be able to read it.
check with:
 gdalinfo --formats
if ECW is not there you will need to rebuild GDAL with support for those.
I am pretty sure that ECW support is not built by default.
 see http://www.gdal.org/frmt_ecw.html
Now that ERmapper has been bought by Leica (apparently erdas has too),
obtaining the SDK has changed as they have a much different view of open
source:
"Product enhancements, including:
  * no more restrictions on the distribution of 'Server Software' under
the GPL-style Public Use License Agreement"
.... but what has that been replaced by? Moved to BSD-like or proprietary?
The binary SDK is only available for Windows, so you may be forced to use
GDAL for Windows to export to GeoTiff.   ? Hopefully the new license is
usable for Linux, I don't know. They still offer the source, which is
encouraging.
good luck,
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
