[GRASS-user] File formats in r.in.gdal
Richard Chirgwin rchirgwin at ozemail.com.au
Tue Apr 22 04:00:46 EDT 2008
Hamish wrote:
> Richard Chirgwin wrote:
>> In Grass 6.2, Ubuntu build (yes, there's a more recent version but not
>> yet for the right build), when importing ECWs in r.in.gdal, I receive
>> the "not a supported file format" error. Any ideas?
>> The same error occurs with Globe DEM files (although Globe DEM has been
>> reorganised and I'm not sure I have found the right header files).
> Your copy of GDAL has to be built with support for those formats. Once it
> is, r.in.gdal should be able to read it.
> check with:
>  gdalinfo --formats
> if ECW is not there you will need to rebuild GDAL with support for those.
> I am pretty sure that ECW support is not built by default.
>  see http://www.gdal.org/frmt_ecw.html
> Now that ERmapper has been bought by Leica (apparently erdas has too),
> obtaining the SDK has changed as they have a much different view of open
> source:
> "Product enhancements, including:
>   * no more restrictions on the distribution of 'Server Software' under
> the GPL-style Public Use License Agreement"
> .... but what has that been replaced by? Moved to BSD-like or proprietary?
> The binary SDK is only available for Windows, so you may be forced to use
> GDAL for Windows to export to GeoTiff.   ? Hopefully the new license is
> usable for Linux, I don't know. They still offer the source, which is
> encouraging.
> good luck,
> Hamish
Thanks, Hamish - I didn't realise about the build issue. It may be
easier to avoid ECW!
However, I have overcome the Globe DEM problem by using a different
download method...
Richard
>       ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080422/787400dd/attachment.html
