[GRASS-user] problem with column label using r.cross
Hamish hamish_b at yahoo.com
Tue Jun 24 09:17:37 EDT 2008
> Christian Schwartze
> Ok and thanks, better to look at first within GRASS if
> eveything is working fine
> ;) (in cats/ full category values) Because the reduced line
> comes from QGIS
> (selection tool). I forgot to say that following r.cross I
> do a conversion with
> r.to.vect and export the result to a shapefile. So the
> original label vals were
> mapped to dbf-column type "C". But why exporting only 80 chars?
Does v.db.select show the cut string?
which DB backend? (dbf?)
"db.describe -c vect_map" ?
Hamish
