[GRASS-user] problem with column label using r.cross
Christian Schwartze Christian.Schwartze at uni-jena.de
Tue Jun 24 09:32:04 EDT 2008
Zitat von Hamish <hamish_b at yahoo.com>:
> > Christian Schwartze
> > Ok and thanks, better to look at first within GRASS if
> > eveything is working fine
> > ;) (in cats/ full category values) Because the reduced line
> > comes from QGIS
> > (selection tool). I forgot to say that following r.cross I
> > do a conversion with
> > r.to.vect and export the result to a shapefile. So the
> > original label vals were
> > mapped to dbf-column type "C". But why exporting only 80 chars?
> Does v.db.select show the cut string?
> which DB backend? (dbf?)
v.db.select shows the full length of column label for all data rows - nothing is
missing. I use dbf backend.
> "db.describe -c vect_map" ?
ncols:3
Column 1:cat:INTEGER
Column 2:value:INTEGER
Column 3:label:CHARACTER
Christian.
> Hamish
This mail was sent through http://webmail.uni-jena.de
