[GRASS-user] occurrence of attributes in vektortable
    Moritz Lennert
    mlennert at club.worldonline.be
    Thu Mar 20 17:12:17 EDT 2008
On 07/03/08 19:42, Nikos Alexandris wrote:
> On Fri, 2008-03-07 at 10:20 -0700, Tom Russo wrote:
>> On Fri, Mar 07, 2008 at 03:35:17PM +0100, we recorded a bogon-computron collision of the <nikos.alexandris at felis.uni-freiburg.de> flavor, containing:
> So we end up with (in my example using the table "TrainingSamples" and
> the column "clccode_le"):
> v.db.select -c map=TrainingSamples column=clccode_le | sort -u
> Still,
> I think it's necessary to give a multiplatform solution (meaning a
> solution which works for wingrass as well). So an SQL query should be it
> as far as I understand.
If you use a real SQL backend:
echo "select distinct(ColumnName) from TableName" | db.select
If you want to count the amount of occurences:
echo "select distinct(ColumnName) as ame, count(*) from TableName group
by name" | db.select
Moritz
