[GRASS-user] Error using v.rast.stats script in cigwin and wingrass
maning sambale emmanuel.sambale at gmail.com
Wed May 21 02:30:45 EDT 2008
Hamish,
> hmmm, don't know. the r.cats script should be there- it was included in the
> release source code:
> http://trac.osgeo.org/grass/browser/grass/tags/release_20080423_grass_6_3_0_1/scripts/r.cats
> oh well. the easiest solution is to edit the v.rast.stats script in a text
> editor to rename it, as seen here:
>   http://trac.osgeo.org/grass/changeset/31306
Done!  It's running now.  Will take a while to finish.
> (maybe do the edit in something more advanced than notepad - something that
> can handle UNIX newlines. e.g. TextPad, or nedit in Cygwin)
I use notepad++
Thanks again!
maning
