[GRASS-user] GUI equivalent of command
H.S.Rai hs at raiandrai.com
Sat May 31 01:10:17 EDT 2008
On Sat, May 31, 2008 at 9:22 AM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
>> Could not get it. May I ask for syntax / complete command.
> When you launch GRASS you have 3 windows: GIS-Manager, Map display and
> Output display.
The command given in Output Display shows results in "Monitor X0", and
not in "Map Display 1", which I want. Giving command in Terminal
Window or Output Display, both show result in X-monitor.
H.S.Rai
http://hs.raiandrai.com/
