[GRASS-user] why v.patch -e produces cat column starting from 2?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Nov 12 09:42:28 EST 2008
On Wed, 2008-11-12 at 15:29 +0100, Moritz Lennert wrote:
> > ### Why not with 1??
> I don't know, but is it a problem ? I don't have time to really dig
> into
> the v.patch code right, now...
> In any case category numbers of a patch results using '-e' have no
> relation to category numbers in the original maps, as how would you
> handle the case with map 1 cats=1-3 and map 2 cats=1-3. At least the
> categories of map 2 will have to be changed.
Moritz,
I appreciate your time to explain this. Thank you.
Well, I am sure now about categories and their role :-) but I am unsure
now about whether it is a problem or not :D
When I bomb again into a related problem I'll report back.
Cheers, Nikos
