[GRASS-user] Using v.in.ascii to create elevation vector
José María Michia
jose.maria.michia at gmail.com
Mon Nov 17 01:46:16 EST 2008
2008/11/16 Kurt Springs <ferret_bard en mac.com>:
> Hi folks,
> I am trying to convert ascii files that I bought from the Irish Ordinance
> Survey in to GRASS vector format. These are digital terrain models. I want
> to eventually make a raster surface map and a 3d raster map out
> demonstrating where various archaeological sites are.
> The files the OSI has sent me have a heading set off with "#" on each line,
> then the data. There are three columns, eventually x, y, z. These are
> separated by a space.
I think you should remove the character "#" for all lines with data.
You must go from lines like these:
# x y z
To lineas like these:
x y z
You can do this, using the linux command "sed". You must execute
something like these:
$ sed 's/^#\ *//g' datos_orig.xyz > datos.xyz
> Using v.in.ascii, I checked Create 3D file
> selected the input file, in this case 0834_10.DTM and typed the out put file
> osi0834. The field separator was set to |. I erased this, and left it
> blank. Input file format was set to point.
> I clicked on the Columns tab. I left the SQL blank. Left x=1 y=2 and set
> Z=3.
> When I hit run I got:
> Scanning input for column types...
> Maximum input row length: 33
> Maximum number of columns: 1
> Minimum number of columns: 1
> y column number > minimum last column number
> (incorrect field separator?)
> I put the | back and got the same error.
> I then set the input file format to standard and got:
> Unexpected data in vector head:
> I have a lot of these to convert. Can anyone give me any advice?
If I understood, you must delete the "#". See my previous comment in
this message.
José María
> Kurt
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
