[GRASS-user] G_malloc: out of memory
Kurt Springs ferret_bard at mac.com
Fri Nov 21 15:54:02 EST 2008
Okay that worked (if I do it twice then restart grass, go figure.)
Anyway.  It keeps on happening.  I am trying to snap the nodes along
my coastline.  I also have to draw three lines to enclose my water.
For trying to snap the nodes, I have been using the MOVE VERTEX to
attempt this (as per the book).  I am having a hard time getting it to
snap.  I try increasing magnification, and that is when the G_malloc
likes to strike.  So I want to do this in as few a steps as possible,
and then get out.
Any thoughts.
Kurt
On Nov 20, 2008, at 11:21 PM, Hamish wrote:
> Kurt:
>> I am running into a problem I've never seen before.  I
>> was trying to digitize a vector file.  I had imported it
>> from a dxf file and was trying to close up some vectors
>> points.  Suddenly v.digit closed, and when I tried to reopen
>> I got:
>> v.digit(4314,0xa0371fa0) malloc: *** mmap(size=1207963648)
>> failed (error code=12)
>> *** error: can't allocate region
>> *** set a breakpoint in malloc_error_break to debug
> whenever v.digit crashes try "v.build mapname" to recover.
> Hamish
