[GRASS-user] Problem with the signatures from i.class
Thybério Luna Freire thyberio at gmail.com
Wed Oct 8 21:41:20 EDT 2008
i'm using i.class to generate a signature to run on i.maxlik. The module
read the signature with no problem, but, the class map result shows only one
class and the area that its cover is bigger than the region that i've set in
i.class. Thats a large red rectangle. I tried various standard deviations
but the result is always the same.
what can be happening?
Sorry, i'm brazilian and my english is not very good!
thanks
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081008/f267b338/attachment.html
