[GRASS-user] Problem with v.clean and Breaking at Intersections
Ryan R. Rosario uclamathguy at gmail.com
Sun Sep 14 15:55:49 EDT 2008
Thanks for you reply. I think that is why it did not work. Since this is a
complete shape file, the intersections are already implemented as nodes
apparently. Both the input and the output have the same number of nodes and
they are displayed in v.digit.
I guess the v.patch/v.clean process is more for people using homegrown
shapefiles and the like.
Thanks,
R.
hamish_b wrote:
> Well, there may be no features written to the errors map because no errors
> were found. ??
> If you look at the input and output layers in v.digit do the lines really
> cross without nodes?
> do the input and output maps have the same number of nodes? (v.info)
View this message in context: http://www.nabble.com/Problem-with-v.clean-and-Breaking-at-Intersections-tp19466729p19483741.html
Sent from the Grass - Users mailing list archive at Nabble.com.
