[GRASS-user] How to import grass ASCII grid with comma as a
	separator
    Adam Dershowitz
    adershowitz at exponent.com
    Tue Sep 16 12:29:30 EDT 2008
Translate (tr) is very fast.
If you do:
tr ',' '.' < input_file.txt > out_file.txt
it should do the job pretty quickly.
--Adam
On Sep 16, 2008, at 9:08 AM, Jarekj wrote:
> Hi
> I recived a number of grass ascii grid floating point maps with
> resolution 6000 x8000 (over 300 MB) px with comma (,) instead of
> point (.) as a decimal separator.
> I have problem with import that data due to bad interpretation of
> comma in file. I tiried with find/replace command in gedit but due
> to file size it takes to much time.
> Is some method to import such file without replacing commas with
> points in external text editor
> Jarek
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
