[GRASS-user] How to import grass ASCII grid with comma as a separator
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Thu Sep 18 06:43:25 EDT 2008
Since the comma is used to format decimal numbers in several
countries, I still think a flag to interpret it that way should
be added to all modules affected by this.
I can think of:
v.in.ascii,
r.in.xyz,
r.in.ascii
Any others?
Ben
Adam Dershowitz wrote:
> Translate (tr) is very fast.
> If you do:
> tr ',' '.' < input_file.txt > out_file.txt
> it should do the job pretty quickly.
> --Adam
> On Sep 16, 2008, at 9:08 AM, Jarekj wrote:
>> Hi
>> I recived a number of grass ascii grid floating point maps with
>> resolution 6000 x8000 (over 300 MB) px with comma (,) instead of point
>> (.) as a decimal separator.
>> I have problem with import that data due to bad interpretation of
>> comma in file. I tiried with find/replace command in gedit but due to
>> file size it takes to much time.
>> Is some method to import such file without replacing commas with
>> points in external text editor
>> Jarek
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeology Ltd
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
