[GRASS-user] Error in sqlite3_step()
Craig Leat craig.leat at gmail.com
Fri Apr 3 11:06:39 EDT 2009
Moritz Lennert wrote:
> Don't have time to look into this now, but it must be a problem in the
> special sqlite implementation in that script:
> if [ "$driver" = "sqlite" ] ; then
>        #echo "Using special trick for SQLite"
>        # http://www.sqlite.org/faq.html#q13
>        v.info --q -c map=$GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d'|' -f1,2
> | grep -v "|${col}$" > "$TMP.coldesc"
>        # need to revert order:
>        cat "$TMP.coldesc" | cut -d'|' -f1 > "$TMP.coltypes"
>        cat "$TMP.coldesc" | cut -d'|' -f2 > "$TMP.colnames"
>        COLDEF=`paste -d' ' "$TMP.colnames" "$TMP.coltypes" | tr '\n' ',' |
> sed 's+,$++g'`
>        COLNAMES=`cat "$TMP.colnames" | tr '\n' ',' | sed 's+,$++g'`
> echo "BEGIN TRANSACTION;
> CREATE TEMPORARY TABLE ${table}_backup(${COLDEF});
> INSERT INTO ${table}_backup SELECT ${COLNAMES} FROM ${table};
> DROP TABLE ${table};
> CREATE TABLE ${table}(${COLDEF});
> INSERT INTO ${table} SELECT ${COLNAMES} FROM ${table}_backup;
> DROP TABLE ${table}_backup;
> COMMIT;" > "$TMP"
> db.execute input="$TMP"
My execute statement looks like this:
BEGIN TRANSACTION;
CREATE TEMPORARY TABLE SBC2_backup(cat INTEGER,LM CHARACTER,WARD
INTEGER,CLASS_NAME CHARACTER);
INSERT INTO SBC2_backup SELECT cat,LM,WARD,CLASS_NAME FROM SBC2;
DROP TABLE SBC2;
CREATE TABLE SBC2(cat INTEGER,LM CHARACTER,WARD INTEGER,CLASS_NAME CHARACTER);
INSERT INTO SBC2 SELECT cat,LM,WARD,CLASS_NAME FROM SBC2_backup;
DROP TABLE SBC2_backup;
COMMIT;
Why does v.db.dropcol define a type CHARACTER when sqlite3 supports
(NULL, INTEGER, REAL, TEXT, BLOB)?
Craig
