[GRASS-user] Error in sqlite3_step()
Moritz Lennert mlennert at club.worldonline.be
Mon Apr 6 05:41:07 EDT 2009
On 03/04/09 17:06, Craig Leat wrote:
> Moritz Lennert wrote:
>> Don't have time to look into this now, but it must be a problem in the
>> special sqlite implementation in that script:
>> if [ "$driver" = "sqlite" ] ; then
>>        #echo "Using special trick for SQLite"
>>        # http://www.sqlite.org/faq.html#q13
>>        v.info --q -c map=$GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d'|' -f1,2
>> | grep -v "|${col}$" > "$TMP.coldesc"
>>        # need to revert order:
>>        cat "$TMP.coldesc" | cut -d'|' -f1 > "$TMP.coltypes"
>>        cat "$TMP.coldesc" | cut -d'|' -f2 > "$TMP.colnames"
>>        COLDEF=`paste -d' ' "$TMP.colnames" "$TMP.coltypes" | tr '\n' ',' |
>> sed 's+,$++g'`
>>        COLNAMES=`cat "$TMP.colnames" | tr '\n' ',' | sed 's+,$++g'`
>> echo "BEGIN TRANSACTION;
>> CREATE TEMPORARY TABLE ${table}_backup(${COLDEF});
>> INSERT INTO ${table}_backup SELECT ${COLNAMES} FROM ${table};
>> DROP TABLE ${table};
>> CREATE TABLE ${table}(${COLDEF});
>> INSERT INTO ${table} SELECT ${COLNAMES} FROM ${table}_backup;
>> DROP TABLE ${table}_backup;
>> COMMIT;" > "$TMP"
>> db.execute input="$TMP"
> My execute statement looks like this:
> BEGIN TRANSACTION;
> CREATE TEMPORARY TABLE SBC2_backup(cat INTEGER,LM CHARACTER,WARD
> INTEGER,CLASS_NAME CHARACTER);
> INSERT INTO SBC2_backup SELECT cat,LM,WARD,CLASS_NAME FROM SBC2;
> DROP TABLE SBC2;
> CREATE TABLE SBC2(cat INTEGER,LM CHARACTER,WARD INTEGER,CLASS_NAME CHARACTER);
> INSERT INTO SBC2 SELECT cat,LM,WARD,CLASS_NAME FROM SBC2_backup;
> DROP TABLE SBC2_backup;
> COMMIT;
> Why does v.db.dropcol define a type CHARACTER when sqlite3 supports
> (NULL, INTEGER, REAL, TEXT, BLOB)?
v.db.dropcol just uses the output of v.info -c, and AFAIR, SBC2 has its
columns defined as CHARACTER, or ?
Moritz
