[GRASS-user] r.patch not working
Renae Mackas rmackas at sfu.ca
Mon Apr 20 18:37:41 EDT 2009
Michael Barton wrote:
> On Apr 15, 2009, at 12:46 AM, <grass-user-request at lists.osgeo.org>
>  > wrote:
>> Renae,
>> On Wed, Apr 15, 2009 at 7:16 AM, Renae Mackas <rmackas at sfu.ca> wrote:
>>> Hello GRASS users-
>>> I am trying to mosaic colourcomposites from LANDSAT images.  A few
>>> weeks ago, I had luck doing this using r.patch with the -z flag
>>> such as below:
>>> r.patch -z input=020.020.2000.055_rgb,021.020.2000.014_rgb,
>>> 021.021.2000.142_rgb,022.020.2000.005_rgb output=mosaic
>>> When I try doing this now however, r.patch does not seem to be
>>> working.  In the output window, it shows a red cirle with an "X" in
>>> it next to the command, but does not print any error message
>>> below.  I have tried patching even just the original rasters
>>> (rather than the rgb composites), and continue to get the same
>>> results.
>>> Since the initial (successful) attempts with r.patch, I have
>>> extended the boundaries of the region I am working with and
>>> imported rasters from other locations.  All of the image rasters
>>> are currently within the region boundaries though.  Is there any
>>> reason why the changes I have made would have changed how r.patch
>>> functions?  Any suggestions of how to get it working again?
>> r.patch (like almost all rast commands) respect the current region.
>> You need to first set the  current region to all raster maps of
>> interest,
>> then run r.patch:
>> g.region rast=020.020.2000.055_rgb,021.020.2000.014_rgb,
>> -p
>> r.patch ...
>> Hope this helps
>> Markus
> You don't say which GRASS version you are running and which platform
> you are using. Recently, we've run into the problem that random
> modules like r.patch do not work or work intermittently in Windows
> Vista using the OSGEO4W installer of GRASS 6.4RC3. A new binary
> installer for GRASS 6.4RC4 hopefully solves this problem.
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Hi Michael-
I was using GRASS 6.3.0 on windows vista.  Being that the current region was
set to the rasters and I still was having problems, I suspect that I may
have just been having temproary problems with r.patch.  I will try updating
my version of GRASS and see if that helps.
Thanks,
Renae
View this message in context: http://n2.nabble.com/r.patch-not-working-tp2637005p2666902.html
Sent from the Grass - Users mailing list archive at Nabble.com.
