[GRASS-user] Re: Georectify problem
Michael Barton Michael.Barton at asu.edu
Wed Dec 2 12:11:44 EST 2009
If you have a second python and it is in your python path, you'll have
trouble. Do you know what the Macports "python_select" script does?
You really don't need to install any extra Python because your Mac
already comes with Python 2.6, the most up-to-date of the 2.x series.
It should not be necessary to run anything downloaded from MacPorts as
any Python app should use the system Python unless it needs an earlier
version. If MacPorts is installing 2.3 or 2.4 this could be a pretty
big headache since GRASS requires at least 2.4 and possibly 2.5 or
above to run its wxPython GUI (we've tried not to break 2.4
compatibility but I haven't tested it). I've heard of other people
having trouble with conflicts from MacPorts. I uses to use Fink but
ran into some of the same issues. And by now I don't really need it
since many applications are now available on the Mac in a more native
way. You might try getting rid of the MacPorts Python and see if GRASS
run--and if MacPorts Python apps still run.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 2, 2009, at 10:00 AM, Adam Dershowitz, Ph.D., P.E. wrote:
> I do have python installed as I have a bunch of things installed
> with macports and some of them depend on it and so installed it as
> part of the builds.  So I can't really get rid of it.  But, as part
> of macports, I do have python_select, which is a small port that
> allows me to switch which python is active and I am currently using
> the Apple installed Python 2.6, not one of the Macport installed
> versions.  So I don't think that is the problem....?
> I am downloading one of your builds to test out right now.
> Thanks,
> --Adam
> On Dec 2, 2009, at 8:53 AM, Michael Barton wrote:
>> Did you install Python yourself? If so, you will need to get rid of
>> it. I know how to do so with 10.5, but am not sure of 10.6. William
>> might be able to offer guidance on this.
>> If you did not install a separate Python, I'm not sure what the
>> problem is. But you can try one of my builds. They work with Snow
>> Leopard on at least one student machine I know of. I've posted very
>> recent binaries for 6.4, 6.5, and 7.0.
>> http://www.public.asu.edu/~cmbarton/files/grass_mac
>> Michael
>> C. Michael Barton
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> On Dec 2, 2009, at 9:44 AM, Adam Dershowitz, Ph.D., P.E. wrote:
>>> Sorry, Mac 10.6.2 using William Kyngesburye's binary builds.
>>> --Adam
>>> On Dec 2, 2009, at 8:35 AM, Michael Barton wrote:
>>>> What OS platform?
>>>> Michael
>>>> C. Michael Barton
>>>> Change
>>>> Phone: 480-965-6262
>>>> Fax: 480-965-7671
>>>> On Dec 2, 2009, at 9:34 AM, Adam Dershowitz, Ph.D., P.E. wrote:
>>>>> I did try it, but I can't currently get it to run.  My guess is
>>>>> that it is an issue of the current built of GRASS that I am
>>>>> using (6.4 RC5-3 on a 64 bit machine):
>>>>> g.gui wxpython
>>>>> Traceback (most recent call last):
>>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/
>>>>> wxgui.py", line 55, in <module>
>>>>> import gui_modules.globalvar as globalvar
>>>>> gui_modules/globalvar.py", line 59, in <module>
>>>>> import wx
>>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/
>>>>> __init__.py", line 45, in <module>
>>>>> from wx._core import *
>>>>> _core.py", line 4, in <module>
>>>>> import _core_
>>>>> ImportError: dlopen(/Applications/GRASS-6.4.app/Contents/MacOS/
>>>>> etc/python/wx/_core_.so, 2): no suitable image found.  Did find:
>>>>> _core_.so: mach-o, but wrong architecture
>>>>> --Adam
>>>>> On Dec 2, 2009, at 6:47 AM, Michael Barton wrote:
>>>>>> Important to note that this will not work with Windows, since
>>>>>> Windows doesn't run x11 unless you the Cygwin unix emulator.
>>>>>> Have you tried georectification with the new wxPython GUI?
>>>>>> Michael
>>>>>> On Dec 1, 2009, at 11:20 PM, grass-user-request at lists.osgeo.org
>>>>>> wrote:
>>>>>>> Date: Wed, 02 Dec 2009 15:01:23 +1100
>>>>>>> From: Richard Chirgwin <rchirgwin at ozemail.com.au>
>>>>>>> Subject: [GRASS-user] Re: Georectify problem
>>>>>>> To: grass-user at lists.osgeo.org
>>>>>>> Message-ID: <4B15E693.1010909 at ozemail.com.au>
>>>>>>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>>>>>> Adam,
>>>>>>> If all else fails, work with a command line process ... I've
>>>>>>> never had
>>>>>>> happy experiences with the purely GUI rectification.
>>>>>>> i.group (groupname) (mapname)
>>>>>>> i.target (groupname) Target_Location Target_Mapset
>>>>>>> d.mon X0
>>>>>>> i.points (groupname) - this launches the GCP capture GUI (old
>>>>>>> style,
>>>>>>> X-windows but it works!)
>>>>>>> i.rectify (groupname) extension="something" order=(polynomial
>>>>>>> order)
>>>>>>> RC
>>>>>> _______________________________________________
>>>>>> grass-user mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
