[GRASS-user] Re: Georectify problem
Adam Dershowitz, Ph.D., P.E. adershowitz at exponent.com
Wed Dec 2 12:00:53 EST 2009
I do have python installed as I have a bunch of things installed with macports and some of them depend on it and so installed it as part of the builds.  So I can't really get rid of it.  But, as part of macports, I do have python_select, which is a small port that allows me to switch which python is active and I am currently using the Apple installed Python 2.6, not one of the Macport installed versions.  So I don't think that is the problem....?
I am downloading one of your builds to test out right now.
Thanks,
--Adam
On Dec 2, 2009, at 8:53 AM, Michael Barton wrote:
> Did you install Python yourself? If so, you will need to get rid of it. I know how to do so with 10.5, but am not sure of 10.6. William might be able to offer guidance on this.
> If you did not install a separate Python, I'm not sure what the problem is. But you can try one of my builds. They work with Snow Leopard on at least one student machine I know of. I've posted very recent binaries for 6.4, 6.5, and 7.0.
> http://www.public.asu.edu/~cmbarton/files/grass_mac
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Dec 2, 2009, at 9:44 AM, Adam Dershowitz, Ph.D., P.E. wrote:
>> Sorry, Mac 10.6.2 using William Kyngesburye's binary builds.
>> --Adam
>> On Dec 2, 2009, at 8:35 AM, Michael Barton wrote:
>>> What OS platform?
>>> Michael
>>> C. Michael Barton
>>> Phone: 480-965-6262
>>> Fax: 480-965-7671
>>> On Dec 2, 2009, at 9:34 AM, Adam Dershowitz, Ph.D., P.E. wrote:
>>>> I did try it, but I can't currently get it to run.  My guess is that it is an issue of the current built of GRASS that I am using (6.4 RC5-3 on a 64 bit machine):
>>>> g.gui wxpython
>>>> Traceback (most recent call last):
>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 55, in <module>
>>>> import gui_modules.globalvar as globalvar
>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gui_modules/globalvar.py", line 59, in <module>
>>>> import wx
>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/__init__.py", line 45, in <module>
>>>> from wx._core import *
>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line 4, in <module>
>>>> import _core_
>>>> ImportError: dlopen(/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so, 2): no suitable image found.  Did find:
>>>> 	/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so: mach-o, but wrong architecture
>>>> --Adam
>>>> On Dec 2, 2009, at 6:47 AM, Michael Barton wrote:
>>>>> Important to note that this will not work with Windows, since Windows doesn't run x11 unless you the Cygwin unix emulator.
>>>>> Have you tried georectification with the new wxPython GUI?
>>>>> Michael
>>>>> On Dec 1, 2009, at 11:20 PM, grass-user-request at lists.osgeo.org wrote:
>>>>>> Date: Wed, 02 Dec 2009 15:01:23 +1100
>>>>>> From: Richard Chirgwin <rchirgwin at ozemail.com.au>
>>>>>> Subject: [GRASS-user] Re: Georectify problem
>>>>>> To: grass-user at lists.osgeo.org
>>>>>> Message-ID: <4B15E693.1010909 at ozemail.com.au>
>>>>>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>>>>> Adam,
>>>>>> If all else fails, work with a command line process ... I've never had
>>>>>> happy experiences with the purely GUI rectification.
>>>>>> i.group (groupname) (mapname)
>>>>>> i.target (groupname) Target_Location Target_Mapset
>>>>>> d.mon X0
>>>>>> i.points (groupname) - this launches the GCP capture GUI (old style,
>>>>>> X-windows but it works!)
>>>>>> i.rectify (groupname) extension="something" order=(polynomial order)
>>>>>> RC
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
