[GRASS-user] Re: CYGWIN
Sat Dec 5 05:05:08 EST 2009
Hamish wrote:
> > Is it a matter of trying compiling on Cygwin? I assume that
> > gdb is the debugger of gcc.
> I'm not sure if a recompile in needed. Glynn, are those binaries
> compiled with -g and not stripped?
The Cygwin binaries are stripped.
Normally, I'd mention that you can still get a backtrace from stripped
binaries.
But in retrospect, the stackdump file says "probably corrupted stack",
so I don't think that you could get a backtrace even if the binaries
weren't stripped.
At this point, I'm out of ideas.
