[GRASS-user] r.proj: fixing a failure
Tue Dec 22 20:47:00 EST 2009
Rich Shepard wrote:
> > Otherwise, if someone replies to one of your posts with "reply to all"
> > (which was the case for Maciej's reply), mailman won't send you a copy. If
> > the copy which was sent directly to you then gets dropped by a spam
> > filter, you won't see the message at all.
>    Well, if the duplicate copy block is set to 'yes,' but my address was
> either the primary or in the cc field, shouldn't I get either the one To: me
Provided that it wasn't blocked by a spam filter.
> or the one To: grass-users at lists.osgeo.org?
No; the anti-duplicates option prevents that from being sent when
you're listed in the To/CC headers.
Mailman only knows whether you were listed in the To/CC headers; it
doesn't know whether you actually received the email directly from the
sender.
