[GRASS-user] Algorithm in flow direction
Markus Metz markus.metz.giswork at googlemail.com
Thu Feb 5 16:18:41 EST 2009
margherita wrote:
> Hi all
> i have some question about the commands r.watershed and r.terraflow.
> By using both commands i obtained from a DEM a flow accumulation with
> the algorithm of the single flow direction and a flow accumulation
> with the algorithm of the multi flow direction. In both cases i did
> not enter the treshold of cell (i.e. in the flow accumulation if a
> grid cell value exceeds a certain threshold, it's part of the river,
> if not, it isn't)
> Please can you let me know if there are default values of this
> threshold and, if yes, what they are, and if that value can be changed
> by the user and how.
This threshold can be set with the option threshold=some_value in
r.watershed (details are in the manual, please read it). r.terraflow
doesn't have such an option (details are in the manual, please read it).
If the option threshold=some_value is given for r.watershed, you can
also get basins, half basins, and stream segments. Maybe these stream
segments are what you are looking for.
Good luck,
Markus M
