[GRASS-user] Appropriate use of v.surf.rst (lidar data)
Wesley Roberts wroberts at csir.co.za
Wed Feb 11 04:22:02 EST 2009
Dear Grass Users,
I am having trouble with interpolating a canopy height model using v.surf.rst and some lidar data. The lidar point density ranges from 5 - 8 points per meter squared. I know I can import the data using r.in.xyz but I would prefer to use an interpolation technique as opposed to a spatial average. I chose r.surf.xyz based on the paper written by Helena Mitasova, Lubos Mitas, and Russell S. Harmon. While the applications differ the use of a large data set with many points means dealing with the same issues. I ran the algorithm using default values and the result was a smooth moon-like surface not really approximating a plantation forest canopy (see link 2)
v.surf.rst input=AreaOne_4pts at Wesley layer=1 zcolumn=dbl_3 elev=Area1_4_def tension=40. segmax=40 npmin=300 dmin=0.050000 dmax=0.250000 zmult=1.0
Given that I am working with very dense data with a high number of points I then ran the algorithm with a smaller tension value (roughly 2.5) with an incrase in the maximum number of points per segment (decrese computation time) and I find that the interpolation is blocky in nature. (see link 3)
v.surf.rst input=AreaOne_4pts at Wesley layer=1 zcolumn=dbl_3 elev=Area1_4_def6 tension=2.5 smooth=0.0001 segmax=100 npmin=300 dmin=0.050000 dmax=0.250000 zmult=1.0
Is the blockiness related to the increase in the maximum number of points in a segment i.e. segmax value?
I have also been looking at using R to do the interpolation using gstat or automap. Does anyone on the list have any
advice with regards to methods to use for the interpolation of lidar canopy returns, with a view to creating a 3-D model
of the canopy. The website spatial-analyst (http://spatial-analyst.net) suggests the use of regression-kriging but
I don't have any ancillary data besides height and intensity.
I have uploaded pics of the study area and interpolation results to flickr (everyone should have access to these)
Link 1
http://www.flickr.com/photos/35273872@N07/3271646498/
Link 2
http://www.flickr.com/photos/35273872@N07/3270854029/
Link 3
http://www.flickr.com/photos/35273872@N07/3270904761/
Many thanks for taking the time to read my post and for your valuable contributions
Wesley (I am using Grass 6.3.0 on Ubuntu Hardy Heron)
Wesley Roberts MSc.
Researcher: Earth Observation (Ecosystems)
Natural Resources and the Environment
CSIR
Tel: +27 (21) 888-2490
Fax: +27 (21) 888-2693
"To know the road ahead, ask those coming back."
- Chinese proverb
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean.  MailScanner thanks Transtec Computers for their support.
