[GRASS-user] v.digit
FAROUX STEPHANIE stephanie.faroux at meteo.fr
Thu Feb 19 11:49:33 EST 2009
Nikos Alexandris wrote:
> On Thu, 2009-02-19 at 17:28 +0100, FAROUX STEPHANIE wrote:
>> Hello,
>> I try v.digit; i want to define a new outline. When i want to close the
>> outline, it opens a window form: attributes; new record was created.
>> Assume data encoding as: [choice between utf-8,ascii,iso88859-1,koi8-t];
>> i do submit and i have the error:
>> Cannot update table:
>> DBMI-DBF driver error:
>> SQL parser error in statement:
>> update australia set  where cat = 4
>> Error in db_execute_immediate()
>> Could you help me?
>> Thank you
> First things to try:
> db.connect -p
> v.db.connect -g YourVectorMap
> Nikos
Yes i forgot to connect but it isn't enough to work...
I also try db.tables but i have the error:
Cannot open dbf database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/australia.dbf
