[GRASS-user] v.digit
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu Feb 19 11:56:55 EST 2009
FAROUX STEPHANIE:
> >> Hello,
> >> I try v.digit; i want to define a new outline. When i want to close the
> >> outline, it opens a window form: attributes; new record was created.
> >> Assume data encoding as: [choice between utf-8,ascii,iso88859-1,koi8-t];
> >> i do submit and i have the error:
> >> Cannot update table:
> >> DBMI-DBF driver error:
> >> SQL parser error in statement:
> >> update australia set  where cat = 4
> >> Error in db_execute_immediate()
> > First things to try:
> > db.connect -p
> > v.db.connect -g YourVectorMap
> Yes i forgot to connect but it isn't enough to work...
> I also try db.tables but i have the error:
> Cannot open dbf database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/australia.dbf
Is the table in the database already present?
# check with
db.tables -p
# if not, then
v.db.addtable YourVectorMap
# if it is... then (shrug)
