[GRASS-user] v.digit
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu Feb 19 11:59:15 EST 2009
On Thu, 2009-02-19 at 17:56 +0100, Nikos Alexandris wrote:
> FAROUX STEPHANIE:
> > >> Hello,
> > >> I try v.digit; i want to define a new outline. When i want to close the
> > >> outline, it opens a window form: attributes; new record was created.
> > >> Assume data encoding as: [choice between utf-8,ascii,iso88859-1,koi8-t];
> > >> i do submit and i have the error:
> > >> Cannot update table:
> > >> DBMI-DBF driver error:
> > >> SQL parser error in statement:
> > >> update australia set  where cat = 4
> > >> Error in db_execute_immediate()
> > > First things to try:
> > > db.connect -p
> > > v.db.connect -g YourVectorMap
> > Yes i forgot to connect but it isn't enough to work...
> > I also try db.tables but i have the error:
> > Cannot open dbf database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/australia.dbf
Ah, ok! Sorry...
What exactly does db.tables -p say?
Did you move the (grass-)database to another directory from last time
you worked in this location?
