[GRASS-user] v.external does not create vector layer
John R. johnr at wowway.com
Mon Feb 23 20:05:21 EST 2009
Hello,
I am running GRASS 6.3.0 on Linux.  I would like to use a postgis table
as a read only vector layer in GRASS.
One time I had v.external doing more than it does now.  Here is a
typical execution:
# v.external 'dsn=PG:host=localhost user=postgres dbname=spatial_db'
output=gpxpints_pg
Data source contains 1 layers:
trackpnt
This would be the behavior I would expect if "output" was not defined.
There is no vector layer created in GRASS.
What is the next debugging step here?
John
