[GRASS-user] categories in raster map
Moritz Lennert mlennert at club.worldonline.be
Thu Feb 26 08:21:01 EST 2009
On 26/02/09 14:01, FAROUX STEPHANIE wrote:
>>>>> On 26/02/09 11:47, FAROUX STEPHANIE wrote:
>>>>>> Hello,
>>>>>> I see the function r.cats which allows to read categories of a
>>>>>> raster map, but how can i define these attributes? Should i pass
>>>>>> by a vector map? In the database menu, it doesn't seem possible to
>>>>>> add a table for a raster map.
>>>>> Raster maps have categories and labels. Categories have to be
>>>>> numerical, labels can be anything. Each pixel needs to have a
>>>>> category value (or NULL) and optionally you can have one (and only
>>>>> one) label per category value.
>>>>> BTW, r.cats is now replaced by r.category.
>>>>> If you want to link a cell with many attributes, you will have to
>>>>> use vector grids (v.mkgrid or r.to.vect as you suggestà).
>>>>> Moritz
>>>> Thank you. And how do you put labels on categories please?
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> I use r.reclass that's it?
>> No, r.reclass "changes" category values, not labels.
>> I think it would be better if you explained a bit more clearly what
>> you want to do, i.e. what do you have and what would you like to have.
>> Normally, r.category seems to be what you are looking for, using the
>> rules= option.
>> I do see that the man page might not be particularly clear on its
>> usage (the Description part only mentions printing, not managing
>> labels and the part on dynamic labels is a bit cryptic). But the
>> section "Input from a file" should give you what you need.
>> Moritz
> Ok. I see it in the manual page of the 6.5 version.
It's been there since 6.3, which was released almost a year ago...
> Actually i work with the 6.2 version (i'm at office and i haven't
> "control" on the installed version) and i think r.cats doesn't have this
> option.
No.
> But with r.reclass i achieved.
Ok, you could also look at r.support for interactive editing of the labels.
> Here i have a map with integer categories values; i want to recode these
> categories but keep old values as labels.
Depending on what you mean by recode, you could also check out r.recode.
Moritz
