[GRASS-user] Determine surface areas
Moritz Lennert mlennert at club.worldonline.be
Fri Feb 27 06:04:40 EST 2009
On 27/02/09 09:53, Nikolaus Arnold wrote:
> Hi!
> I am new to using GIS and GRASS.
> I am currently working on a task where I have to determine the type of
> surface around a specific coordinate. For example what is the total
> water surface area in a 100km radius around the Eiffeltower.
> I have found a landcover map (
> http://glcf.umiacs.umd.edu/data/landcover/ ) with a 1km raster that
> isn't perfect but should do the job.
If it is for Europe, you might want to check out Corine Landcover [1]
which has a resolution of 1 ha.
> After some time I managed
> displaying the map and showing only specific values in GRASS. My next
> step would have been exporting the map to an image, draw the desired
> circles with a image editing tool and count the contained fields manually.
> But taking a closer look at GRASS and the vectormap function, I wondered
> if it would be possible to create vector circles, merge them with the
> existing map and let GRASS do the work of counting the Areas.
> Does this seem possible? If yes, what would be the first steps?
1) Use buffering to create desired buffers: r.buffer or v.buffer
(possibly + v.to.rast)
2) Calculate statistics of land use per buffer: r.stats, r.report if you
use raster buffers, v.rast.stats if you use vector buffers
Moritz
[1]http://dataservice.eea.europa.eu/dataservice/metadetails.asp?id=1007
and http://www.eea.europa.eu/themes/landuse/clc-download
