[GRASS-user] grass' build problem with libtoolize
Markus Neteler neteler at osgeo.org
Tue Jan 6 14:55:37 EST 2009
On Tue, Jan 6, 2009 at 7:05 PM, MORREALE Jean Roc
<jr.morreale at enoreth.net> wrote:
>> I am using Mandriva 2009.0 and have no problems.
>> But libtool isn't used/usable for GRASS, probably that's the
>> source of the problem. We need to know more specifically
>> what you plan to do.
> Here is my spec file ->
> http://pastebin.mandriva.com/5551
I have updated it a bit but can now reproduce the problem.
It is a specialty when building RPMs.
> It is based on the latest available on mandriva's contrib, I've not done
> much modifications except cleaning the rust and add the correct dependencies
> for the new gui. The spec file in the tarball you mentioned is an older
> version.
Older version yes, but with updates to 2009.x. I have updated that
again (new URLs) and also updated yours (will send offlist).
> I want to submit a newer grass' package since I need it to submit qgis 1.0
> and also because the actual one on cooker's svn is nearly one year old,
> conflicts over libavcodec due to wrong include's path, etc.
Excellent.
> The libtool thingy is set to be used by default in mandriva's rpmbuild.
Right and an addition in GRASS 6.4.x causes the trouble. I have opened
a ticket for that:
 http://trac.osgeo.org/grass/ticket/424
Feel free to add yourself in copy to watch it.
Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
