[GRASS-user] grass' build problem with libtoolize
Markus Neteler neteler at osgeo.org
Tue Jan 6 15:18:49 EST 2009
On Tue, Jan 6, 2009 at 8:55 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Jan 6, 2009 at 7:05 PM, MORREALE Jean Roc
> <jr.morreale at enoreth.net> wrote:
>>> I am using Mandriva 2009.0 and have no problems.
>>> But libtool isn't used/usable for GRASS, probably that's the
>>> source of the problem. We need to know more specifically
>>> what you plan to do.
>> Here is my spec file ->
>> http://pastebin.mandriva.com/5551
> I have updated it a bit but can now reproduce the problem.
> It is a specialty when building RPMs.
Found a workaround: replace
%configure
with
./configure
and libtoolize is no longer used.
Two fixes are necessary, then it compiles (running here now).
I'll send you the SPEC file.
Markus
