[GRASS-user] table entry for every geometry object(s id)
achim ak7 at jupiter.uni-freiburg.de
Fri Jun 26 06:45:26 EDT 2009
...I mean: how to get an table entry for every vector objects Id? (every
geometry object has an unique id)
achim wrote:
> Yes, thanks,
> but how to force that every single geometry object (of one kind) gets an
> entry?
> Achim
> (just to mention: And why aren't those commands reachable in an useful
> order? One always has to check whether the table are built, go and add a
> table, on another place set connection, on another place load up
> cats...alway confusing and lots of clicking in the gui)
> Moritz Lennert wrote:
>> On 26/06/09 11:30, achim wrote:
>>> Hi all,
>>> I think I am not the only one having problems with getting the
>>> connection "vector geometry features" - "attribute table" (for me its
>>> a sqlite db at the moment). ;-)
>>> So I wonder how is the default way to deal with vector layers to
>>> establish a metadata table to each geometry object?
>> Normally, categories are added and a table is automatically created at
>> vector import, or, by default, at digitalisation. But some modules do
>> not create a table as they wouldn't know what to put in it (and a
>> table with just cat values is not very useful as such).
>>> I always have the problem that the table is empty. And adding
>>> category is not enough to add an entry for every geometry object...
>>> well.
>> After adding the category, you have to upload it to the table with
>> v.to.db.
>> If you do not even have a table connected to the map, you can run the
>> script v.db.addtable which creates the table (by running an SQL query)
>> and then adds the category values to it (with v.to.db).
>> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
