[GRASS-user] tables connection in database
achim ak7 at jupiter.uni-freiburg.de
Fri Jun 26 06:10:42 EDT 2009
Yes, thanks,
but how to force that every single geometry object (of one kind) gets an
entry?
Achim
(just to mention: And why aren't those commands reachable in an useful
order? One always has to check whether the table are built, go and add a
table, on another place set connection, on another place load up
cats...alway confusing and lots of clicking in the gui)
Moritz Lennert wrote:
> On 26/06/09 11:30, achim wrote:
>> Hi all,
>> I think I am not the only one having problems with getting the
>> connection "vector geometry features" - "attribute table" (for me its
>> a sqlite db at the moment). ;-)
>> So I wonder how is the default way to deal with vector layers to
>> establish a metadata table to each geometry object?
> Normally, categories are added and a table is automatically created at
> vector import, or, by default, at digitalisation. But some modules do
> not create a table as they wouldn't know what to put in it (and a table
> with just cat values is not very useful as such).
>> I always have the problem that the table is empty. And adding category
>> is not enough to add an entry for every geometry object... well.
> After adding the category, you have to upload it to the table with v.to.db.
> If you do not even have a table connected to the map, you can run the
> script v.db.addtable which creates the table (by running an SQL query)
> and then adds the category values to it (with v.to.db).
> Moritz
