[GRASS-user] Testing two vectors for equality
Moritz Lennert mlennert at club.worldonline.be
Sat Jun 27 08:21:32 EDT 2009
On 27/06/09 05:01, Michael Perdue wrote:
> Is there a way to test if two vectors are identical, including their
> attribute tables? i.e., I've changed some code and now I want to test
> that the results are the same. Is there an easy way to do this?
Since 6.5 v.select offers the use of GEOS operators, which includes
'equals'. But this only tests the geometries, so you would have to test
the attribute tables separately.
Moritz
