[GRASS-user] Importing .csv table into GRASS
Markus Neteler neteler at osgeo.org
Mon Jun 29 18:02:10 EDT 2009
you could try the updated version from 6.4:
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/scripts/db.in.ogr/db.in.ogr?format=raw
(not sure if it is compliant to 6.3 but worth a try).
Markus
On Fri, Jun 26, 2009 at 10:34 AM, JanaKr<jkrajc at gmail.com> wrote:
> Hello,
> I am trying to import a simple okresy.csv table, the first few lines of
> which are:
> CAT,AREA,PERIMETER,CISLO_OKR,SO2_KG,SO2_OBYV
> 64,9485480,15278.33,101,3384,0.08
> 66,92488080,53576.26,102,3384,0.03
> 62,74758064,39651.84,103,3384,0.05
> 63,96450584,56394.8,104,3384,0.04
> Using  db.in.ogr okresy.csv out=okresy returns error message:
> Input table <okresy.csv>   not found or not readable
> I am using Linux installation of GRASS 6.3, I tried to use full path to the
> .csv file, I tried to move it to current directory, but the message was
> always the same. Then I thought maybe my .csv file is not OK ... so I
> checked the http://www.gdal.org/ogr/drv_csv.html, but seems OK.
> Does anyone have any clue?
> View this message in context: http://n2.nabble.com/Importing-.csv-table-into-GRASS-tp3160360p3160360.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
