[GRASS-user] grass 6.4 rc5 and python scripting
Hamish hamish_b at yahoo.com
Tue Jun 30 22:35:07 EDT 2009
Ricardo Filipe Soares Garcia da wrote:
> Thanks for your good advice. I decided to go with the
> option of EXPORTing the grass addon path and put my scripts
> there, which works ok, well... kind of.
> It happens that when I launch GRASS from the terminal, the
> GRASS_ADDON_PATH gets correctly added to the PATH and I can
> load my test script. However, if I start GRASS from the gnome
> menu (or gnome-do) the GRASS_ADDON_PATH gets ignored. Maybe
> theres some config file that I have to tweak?
how/where do you set the variable? it needs to be set before
GRASS begins.
in the gnome menu entry prefs do you have "start in terminal" ticked?
Hamish
