[GRASS-user] qgis + grass-plugin = gdal-problem (update)
achim ak7 at jupiter.uni-freiburg.de
Sat Mar 7 13:26:59 EST 2009
Hi Otto,
have you find out, what the problem could be? I am still willing to use
grass with qgis, but -as written- qgis terminates when loading a raster
file from a grass project. I tried an older qgis version, but the error
is the same:
qgis: symbol lookup error: /usr/lib/gdalplugins/gdal_GRASS.so: undefined
symbol: G_no_gisinit
I'm afraid I made something wrong with my openSUSE 11.1 64bit...
Sorry for being so impatient,
achim
achim schrieb:
> I use a 64 bit system and 64 bit packages (for suse 11.1)
> achim
> Otto Dassau schrieb:
>> Hi Achim,
>> I build the opensuse packages in the Application:/Geo repository and will check
>> this. Do you use the 32 bit or 64 bit packages for 11.1?
>> regards,
>>  Otto
>> On Mon, 02 Mar 2009 10:45:00 +0100
>> achim <ak7 at jupiter.uni-freiburg.de> wrote:
>>> Hi,
>>> thanks for answering and sorry for taking so long..
>>> Im running suse 11.1 and I was installing both qgis and grass from the
>>> following repositories:
>>> http://teodori.org/repos/grass/openSuSE11.1/
>>> and
>>> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.1/
>>> As said deinstalling the old and reinstalling of the packages via yast
>>> does not help. Now I'm using only grass, but I would really like to use
>>> the comfortable qgis in future too.
>>> Thanks,
>>> achim
>>> Zahid Parvez schrieb:
>>>>> On Sat, Feb 28, 2009 at 9:09 AM, Nikos Alexandris
>>>>> <nikos.alexandris at felis.uni-freiburg.de
>>>>> <mailto:nikos.alexandris at felis.uni-freiburg.de>> wrote:
>>>>>     On Fri, 2009-02-27 at 13:39 +0100, achim wrote:
>>>>>     > Hi,
>>>>>     > I used the goe-repository files for installing grass (6.4) and
>>>>>     grass63.
>>>>>     > Do I have to compile myself? Cant I clean old libraries by
>>> myself and
>>>>>     > reinstall grass from the repository?
>>>>>     > Thanks,
>>>>>     > achim
>>>>>     Hi Achim!
>>>>>     It's not clear to me which geo-repository you mean. Could you
>>> please be
>>>>>     more specific?
>>>>>     First:
>>>>>     * Which operating system do you use?
>>>>>     * Which exact commands did you use to install grass 6.4 and which to
>>>>>     install grass 6.3?
>>>>>     * Why do you need both, version 6.3 and 6.4?
>>>>>     Now partially answering:
>>>>>     * You are not "forced" to compile grass by yourself. There are
>>> binaries
>>>>>     ready-to-(install)use.
>>>>>     * Of course you can clean old libraries. If you installed grass from
>>>>>     ubuntu's repository for example, it should be easy to clean
>>> everything
>>>>>     by just removing it (preferably with "sudo apt-get purge grass").
>>>>>     BTW, Jachym Cepicky's repository [1] is AFAIK always more up-to-date
>>>>>     than ubuntu's repositories.
>>>>>     Kind regards, Nikos
>>>>>     [1] http://les-ejk.cz/ubuntu/
>>>>>     _______________________________________________
>>>>>     grass-user mailing list
>>>>>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>>>>     http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>> if you use windows xp sp2 this may help. i got this from internet
>>>>> best
>>>>> zahid
