[GRASS-user] qgis + grass-plugin = gdal-problem (update)
Otto Dassau otto.dassau at gmx.de
Sat Mar 7 13:31:09 EST 2009
Hi Achim,
On Sat, 07 Mar 2009 19:26:59 +0100
achim <ak7 at jupiter.uni-freiburg.de> wrote:
> Hi Otto,
> have you find out, what the problem could be? I am still willing to use
> grass with qgis, but -as written- qgis terminates when loading a raster
> file from a grass project. I tried an older qgis version, but the error
> is the same:
> qgis: symbol lookup error: /usr/lib/gdalplugins/gdal_GRASS.so: undefined
> symbol: G_no_gisinit
> I'm afraid I made something wrong with my openSUSE 11.1 64bit...
> Sorry for being so impatient,
I haven't had the time to look at it yet. I will test as soon as possible, but
it will probably take some more days. I am very busy at the moment - sorry.
regards,
 Otto
> achim
> achim schrieb:
> > I use a 64 bit system and 64 bit packages (for suse 11.1)
> > achim
> > Otto Dassau schrieb:
> >> Hi Achim,
> >> I build the opensuse packages in the Application:/Geo repository and will
check
> >> this. Do you use the 32 bit or 64 bit packages for 11.1?
> >> regards,
> >>  Otto
> >> On Mon, 02 Mar 2009 10:45:00 +0100
> >>> Hi,
> >>> thanks for answering and sorry for taking so long..
> >>> Im running suse 11.1 and I was installing both qgis and grass from the
> >>> following repositories:
> >>> http://teodori.org/repos/grass/openSuSE11.1/
> >>> and
> >>> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.1/
> >>> As said deinstalling the old and reinstalling of the packages via yast
> >>> does not help. Now I'm using only grass, but I would really like to use
> >>> the comfortable qgis in future too.
> >>> Thanks,
> >>> achim
> >>> Zahid Parvez schrieb:
> >>>>> On Sat, Feb 28, 2009 at 9:09 AM, Nikos Alexandris
> >>>>> <nikos.alexandris at felis.uni-freiburg.de
> >>>>> <mailto:nikos.alexandris at felis.uni-freiburg.de>> wrote:
> >>>>>     On Fri, 2009-02-27 at 13:39 +0100, achim wrote:
> >>>>>     > Hi,
> >>>>>     > I used the goe-repository files for installing grass (6.4) and
> >>>>>     grass63.
> >>>>>     > Do I have to compile myself? Cant I clean old libraries by
> >>> myself and
> >>>>>     > reinstall grass from the repository?
> >>>>>     > Thanks,
> >>>>>     > achim
> >>>>>     Hi Achim!
> >>>>>     It's not clear to me which geo-repository you mean. Could you
> >>> please be
> >>>>>     more specific?
> >>>>>     First:
> >>>>>     * Which operating system do you use?
> >>>>>     * Which exact commands did you use to install grass 6.4 and which to
> >>>>>     install grass 6.3?
> >>>>>     * Why do you need both, version 6.3 and 6.4?
> >>>>>     Now partially answering:
> >>>>>     * You are not "forced" to compile grass by yourself. There are
> >>> binaries
> >>>>>     ready-to-(install)use.
> >>>>>     * Of course you can clean old libraries. If you installed grass from
> >>>>>     ubuntu's repository for example, it should be easy to clean
> >>> everything
> >>>>>     by just removing it (preferably with "sudo apt-get purge grass").
> >>>>>     BTW, Jachym Cepicky's repository [1] is AFAIK always more up-to-date
> >>>>>     than ubuntu's repositories.
> >>>>>     Kind regards, Nikos
> >>>>>     [1] http://les-ejk.cz/ubuntu/
> >>>>>     _______________________________________________
> >>>>>     grass-user mailing list
> >>>>>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> >>>>>     http://lists.osgeo.org/mailman/listinfo/grass-user
> >>>>> if you use windows xp sp2 this may help. i got this from internet
> >>>>> best
> >>>>> zahid
