[GRASS-user] v.net.path weight & co
Stefano elstefen at gmail.com
Fri May 8 06:23:21 EDT 2009
@hamish, altready try all of these stuff, i'll try with the subtraction, i
hope in that solution!
anyway, after one week of trial my  thought is:
the problem can be:
the way that use v.to.db takes the length, how it measure? where it cut a
line in the intersection and so on
the way that use v.net.path to assign automatically weight (it takes the
length, but how?)
where i can found the code of v.net.path ?
someone of you has a map that are sure to work with v.net.path with weight
(maybe is my map that is malformed, too much lines ar attached an so on)
doesn't exists a method to tell at v.net.path: takes the weight and
multiplies it by the length that you normally calculate?
thanks
Stefano
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090508/213e8fd9/attachment.html
