[GRASS-user] Specifying Units: r.in.gdal Within wxPython -- FIXED
Rich Shepard rshepard at appl-ecosys.com
Fri Nov 13 19:21:43 EST 2009
On Fri, 13 Nov 2009, Rich Shepard wrote:
>  Starting grass64 with the '-wxpython' option does not appear to provide a
> window where I can manually enter a command. I found the menu item for
> r.in.gdal, and that brought up a tabbed window where I could specify the
> location of the hdr.adf. But, when I entered all the data and clicked the
> 'Run' button, an error message appeared that the units were not specified.
   Fixed this, too. For whatever reason, the metadata file's projection
information did not match that of the data files. So, after seeing the
errors, I check the option of overriding the location's data with that in
the file and it's working just fine now.
Rich
