[GRASS-user] computation in a location based on infos from another location
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Thu Nov 19 10:30:55 EST 2009
> use r.to.vect to map every cell to a polygon, project it to the lambert
> map, do the calculation on the polygon, reproject it back to the
you dont need to project it to lambert:
just run v.to.db -p option=area map=...
then you get the size for every lines cell.
To get the raster-map:
r.mapcalc "ns_col=if(col()==1 , row() , null())"
Achim
