[GRASS-user] grass 7 svn gdal
Matthew Mulbrandon mulbran at hotmail.com
Thu Apr 8 22:48:30 EDT 2010
Hello,
Building grass 7 in ubuntu 9.10. Got an error I have seen before on this list.
7.0.svn (demolocation):/usr/local/src/grass_trunk > g.list: error
while loading shared libraries: libgdal.so.1: cannot open shared object
file: No such file or directory
I put in
matthew at matthew-laptop:~$ dpkg -l|grep libgdal
ii  libgdal1-1.5.0                       1.5.4-4                                    Geospatial Data Abstraction Library
ii  libgdal1-1.5.0-grass                 1.5.4-3                                    GRASS extension for the GDAL library
ii  libgdal1-dev                         1.5.4-4                                    Geospatial Data Abstraction Library - Develo
matthew at matthew-laptop:~$ dpkg -l|grep libproj
ii  libproj-dev                          4.6.1-5                                    Cartographic projection library (development
ii  libproj0                             4.6.1-5                                    Cartographic projection library
it does exist but when in grass I do
GRASS 7.0.svn (demolocation):/usr/local/src/grass_trunk > whereis libgdal.so.1
libgdal.so:
libgdal:
GRASS 7.0.svn (demolocation):/usr/local/src/grass_trunk > wheris libgdal libgdal
No command 'wheris' found, did you mean:
 Command 'whereis' from package 'util-linux' (main)
wheris: command not found
GRASS 7.0.svn (demolocation):/usr/local/src/grass_trunk > whereis libgdal libgdal
libgdal:
libgdal:
I
don't think it can find the location because it does not list a dir as
it should. Does that sound correct. If so how do I fix it.
Any help would be great.
Thanks,
Matthew
_________________________________________________________________
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_1
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100409/206a70bc/attachment-0001.html
