[GRASS-user] Using v.surf.rst
Jaros?aw Jasiewicz jarekj at amu.edu.pl
Fri Apr 9 03:44:05 EDT 2010
Eric pisze:
> I’m very new to GRASS and an experienced programmer.
> My goal is to import isolines (elevation lines) as well as elevation
> points from another mapping program into GRASS and then interpolate a
> raster based on the vector data and then export as a DEM file.
> To that end I have reviewed
> http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ascii.html
> http://grass.osgeo.org/grass64/manuals/html64_user/v.surf.rst.html
> I think I understand the principals but am getting stuck on several
> details.
> As a simple test I attempted to create an ASCII file with X Y Z
> coordinates:
> myFile.txt
> 593493|4914730|123
> 591950|4923000|222
> 589860|4922000|232
> 590400|4922820|143
> 593549|4925500|442
> 600375|4925235|342
>  import with
> v.in.ascii –z input=myFile.txt output=secondTry z=3
> I get v.in.ascii complete (no error messages)
> and then
> run v.surf.rst input=secondTry at PERMANENT elev=secondTryRaster
> This yields the error
> some points outside of region -- will ignore...
> there are points outside specified 2D/3D region--ignored 6 points
> ERROR2: zero points in the given region!
> ERROR: Input failed
> Keeping in mind I’m completely new to GRASS (and don’t understand a
> lot of the jargon), can you explain what I’m doing wrong?
> Also, can you recommend a tutorial that covers this type of conversion
> oriented toward beginners?
> Thanks!
> Eric
> After importing the data points, I do not see anything at all visually
> in GRASS GIS Map Display.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
It simply menas that data are outside your region
try:
g.region vect=secondTry
HTH
J.
