[GRASS-user] How to manipulate PostGIS attributes from GRASS
Micha Silver micha at arava.co.il
Sun Apr 18 05:58:02 EDT 2010
I have a PostGIS point layer. I've added an elevation column and I want
to insert values for elevation using v.what.rast . What's the best way
to do this?
I tried:
1- v.external, but that's a read only connection.
2- v.in.ogr -t (to avoid creating a duplicate table), then v.db.connect
to reconnect to the original PostGIS table. But that's *wrong* since
there's no way that I can see to connect the cat values to the data
table id column.
Finally I did:
3- db.connect (to the PostGIS database)
v.in.ogr dsn="PG:..." layer=orig_table out=new_table
to create a new attrib table in Postgresql (geometry in GRASS)
v.what.rast on the new vector to get elevation values into the new
attrib table,
then using a postgres update statement I copied the elevation attributes
from the new table to the original. This does work OK.
Is there smoother way?
Thanks,
Micha
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100418/3198e5b9/attachment.html
