[GRASS-user] Re: Operation of v.split
Wed Apr 21 15:06:54 EDT 2010
"António M. Rodrigues" wrote:
> I have recently compiled GRASS7 (MAC OSX), using:
> All this went fine (after some initial problems). Now, when I startup
> the application I get the following error message:
> '/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
> norte:~ antonio$ '/Applications/GRASS-7.0.app/Contents/MacOS/
> grass.sh'; exit
> Rebuilding Addon HTML manual pages index...
> Rebuilding Addon menu...
> Python 2.5.1 found.
> /Applications/GRASS-7.0.app/Contents/MacOS/grass.sh: line 220: /
> Applications/GRASS-7.0.app/Contents/MacOS/etc/Init.sh: No such file or
> directory
The GRASS startup has been modified (the shell scripts have been
removed in favour of a Python script), but the MacOSX packaging hasn't
been updated to account for this.
> Other than trying to solve the problem with python, I guess the
> simplest thing would be to start GRASS with the older GUI (which I'm
> perfectly happy with, running GRASS6.4 with no problems at all). But
> how do I do this?
You could try installing the Python script (bin.<arch>/grass70) and
using that, although it may require some changes to work work with an
"app" build.
